はじめに
Before beginning this guide make sure to have your soldering workstation ready for use.
必要な工具と部品
To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
After removing all 16 screws you can begin the process of removing the battery housing panel.
You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
Try to be careful around the side buttons as the plastic is weakest there.
After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
The volume buttons are located on the rear-upper-right side of your Blu Studio phone.
Using the tweezers lift the volume buttons and unsolder the buttons connection.
Finally you solder the new buttons to the motherboard of your Blu Studio.
Make sure that your buttons are placed as shown in the picture.
ある他の人がこのガイドを完成しました。
