メインコンテンツにスキップ
Blu Studio HD 6.0 SIM Card Replacement
必要な工具と部品
  1. Blu Studio HD 6.0 SIM Card Replacement, Rear Case: 手順 1、 1の画像 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: 手順 2、 2の画像 1 Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: 手順 2、 2の画像 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 SIM Card Replacement: 手順 3、 2の画像 1 Blu Studio HD 6.0 SIM Card Replacement: 手順 3、 2の画像 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 SIM Card Replacement, Find out if your Blu Studio 6.0 is "unlocked.": 手順 4、 1の画像 1
    • Look at the sticker on top of the battery housing and note the model, part number and type.
    • Research this information to find out if you have an unlocked version of the phone.
    • If your phone is unlocked you can use any mobile network SIM card. If not you must replace the SIM card with a card from your carrier.
  5. Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 手順 5、 3の画像 1 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 手順 5、 3の画像 2 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 手順 5、 3の画像 3
    • If necessary slide the unneeded SIM card out of it's slot.
    • Make sure your new SIM card has been activated by the carrier.
    • Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
  6. Blu Studio HD 6.0 SIM Card Replacement, Turn the phone on: 手順 6、 1の画像 1
    • Turn on your Studio 6.0 and test it to make sure that everything is working.
    • If your phone gives you an error, check your SIM card installation. If everything seems to be correct make sure your SIM card is activated.
    • If everything is working you're good to go.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alec
メンバー登録日: 09/23/14
617 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S9G1
3 メンバー
8のガイドは作成済み
13件のガイドコメント
Okay so my Sim has been working for months just 2 days ago my phone wouldn't turn on and then we'll now it doesn't read the Sim card idk what's going on with this but its getting annoying
caitlin - 返信
i know i am having the same issue. it is saying my sim card is off and to turn it on
jsllndr84 -
Its saying my Sim card is off..how do I turn it on.
victor ayitey - 返信
I just got this phone and I install the sim card like they say and it still says no sim card
Cheryl Dean - 返信
I have activated metro pcs sim. Unlocked blu studio g2 6.0 will not detect sim wtf?
Tim - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 45,176
