メインコンテンツにスキップ
Blu Studio HD 6.0 Microphone Replacement
必要な工具と部品
  1. Blu Studio HD 6.0 Microphone Replacement, Rear Case: 手順 1、 1の画像 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Microphone Replacement, Back Panel.: 手順 2、 2の画像 1 Blu Studio HD 6.0 Microphone Replacement, Back Panel.: 手順 2、 2の画像 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Microphone Replacement: 手順 3、 2の画像 1 Blu Studio HD 6.0 Microphone Replacement: 手順 3、 2の画像 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Microphone Replacement, Midframe: 手順 4、 2の画像 1 Blu Studio HD 6.0 Microphone Replacement, Midframe: 手順 4、 2の画像 2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Microphone Replacement: 手順 5、 1の画像 1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Microphone Replacement: 手順 6、 1の画像 1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Microphone Replacement: 手順 7、 1の画像 1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: 手順 8、 2の画像 1 Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: 手順 8、 2の画像 2
    • The microphone is located at the rear-lower-left corner.
  9. Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: 手順 9、 2の画像 1 Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: 手順 9、 2の画像 2
    • Lift the microphone very carefully.
    • Unsolder the two lower wires ( one red wire and one black wire ).
  10. Blu Studio HD 6.0 Microphone Replacement, Solder the new microphone.: 手順 10、 1の画像 1
    • Solder the new microphone in the same spot. The black wire will go in the lower spot and the red wire in the upper spot.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ernesto Diaz
メンバー登録日: 09/23/14
1,759 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S9G1
3 メンバー
8のガイドは作成済み
2 件のコメント
Where can I get a blue microphone for my BLU phone. When I answer my BLU phone I can't hear the person on the other line but they cannot hear me so I believe it's just my microphone when I speak.
Christina - 返信
Where can I buy microphones
b langdon - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 13,626
