メインコンテンツにスキップ
Blu Studio 5.5 S Speaker Replacement
必要な工具と部品
  1. Blu Studio 5.5 S Speaker Replacement, Back Casing: 手順 1、 1の画像 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Speaker Replacement, Applying Pressure: 手順 2、 3の画像 1 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: 手順 2、 3の画像 2 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: 手順 2、 3の画像 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Speaker Replacement, Battery: 手順 3、 3の画像 1 Blu Studio 5.5 S Speaker Replacement, Battery: 手順 3、 3の画像 2 Blu Studio 5.5 S Speaker Replacement, Battery: 手順 3、 3の画像 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Speaker Replacement, Midframe: 手順 4、 3の画像 1 Blu Studio 5.5 S Speaker Replacement, Midframe: 手順 4、 3の画像 2 Blu Studio 5.5 S Speaker Replacement, Midframe: 手順 4、 3の画像 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Speaker Replacement, Aesthetic Bottom Case: 手順 5、 1の画像 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Speaker Replacement: 手順 6、 3の画像 1 Blu Studio 5.5 S Speaker Replacement: 手順 6、 3の画像 2 Blu Studio 5.5 S Speaker Replacement: 手順 6、 3の画像 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Speaker Replacement, Speaker: 手順 7、 3の画像 1 Blu Studio 5.5 S Speaker Replacement, Speaker: 手順 7、 3の画像 2 Blu Studio 5.5 S Speaker Replacement, Speaker: 手順 7、 3の画像 3
    この手順で使用する道具:
    $3.99
    購入する
    • The speaker is located on the bottom of the back inner case. To remove it, use a pair of angled tweezers.
    • Use the tweezers to remove the speaker off of the casing.
    • Only put the tweezers in enough to gain leverage.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Cody Dyl
メンバー登録日: 10/27/14
804 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G8
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 1,193
