メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
In this guide you will learn where the front facing camera is located in the Blu Studio 5.5 S, along with how to remove and replace it.
パーツ
パーツは指定されていません。
  1. In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Place your finger in the small notch on the left side of the charging port (facing from the back). Once your finger is in the notch, pull the back case towards yourself to remove it. Once your finger is in the notch, pull the back case towards yourself to remove it.
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it. Insert your finger into the notch near the lower left of the battery, apply pressure and lift up. Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  5. The speaker is located behind the inner back case.  Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  6. Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  7. Use the Spudger to pop the inner back casing off.  Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case. Pick up the inner back case and flip it over. Pick up the inner back case and flip it over.
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  8. The frontward facing camera is located in the top left of the phone.  It is connected to the motherboard by a ribbon connector, and a prong system. Use a spudger to detach the front facing camera by flipping the orange tab on the top of the prong system.
    • The frontward facing camera is located in the top left of the phone. It is connected to the motherboard by a ribbon connector, and a prong system.
    • Use a spudger to detach the front facing camera by flipping the orange tab on the top of the prong system.
    • Once the orange tab is up, pull out the orange ribbon wire.
  9. Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit. Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit.
    • Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit.
終わりに
Cody Dyl
メンバー登録日: 2014年10月27日
783 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G8
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,472
