メインコンテンツにスキップ
Blu L120 Loudspeaker Replacement
必要な工具と部品
  1. Blu L120 Loudspeaker Replacement, Open the back panel: 手順 1、 3の画像 1 Blu L120 Loudspeaker Replacement, Open the back panel: 手順 1、 3の画像 2 Blu L120 Loudspeaker Replacement, Open the back panel: 手順 1、 3の画像 3
    • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  2. Blu L120 Loudspeaker Replacement, Screw removal: 手順 2、 3の画像 1 Blu L120 Loudspeaker Replacement, Screw removal: 手順 2、 3の画像 2 Blu L120 Loudspeaker Replacement, Screw removal: 手順 2、 3の画像 3
    • Remove these nine screws with a small philips screwdriver. They are all of the same size
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it.
    • *WARNING* by doing this you will void your manufacturer warranty.
  3. Blu L120 Loudspeaker Replacement, Rear panel removal: 手順 3、 3の画像 1 Blu L120 Loudspeaker Replacement, Rear panel removal: 手順 3、 3の画像 2 Blu L120 Loudspeaker Replacement, Rear panel removal: 手順 3、 3の画像 3
    • Use the Spudger to gently separate the panel from the frame, starting from the bottom left corner.
    • Then work your way along the edges of the phone.
  4. Blu L120 Loudspeaker Replacement, Separate back panel and frame: 手順 4、 3の画像 1 Blu L120 Loudspeaker Replacement, Separate back panel and frame: 手順 4、 3の画像 2 Blu L120 Loudspeaker Replacement, Separate back panel and frame: 手順 4、 3の画像 3
    • Continue using the spudger around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Loudspeaker Replacement, Speaker Removal: 手順 5、 2の画像 1 Blu L120 Loudspeaker Replacement, Speaker Removal: 手順 5、 2の画像 2
    • Use a pair of tweezers to grab the speaker assembly from the back of the panel and gently remove the it from the frame. (double sided tape is used to hold it together)
    • Install the new speaker, and follow the guide in reverse to reassemble the phone.
終わりに
作成者
3人の作成者と共同で作成されました。
Julio
メンバー登録日: 10/25/14
695 ポイント
6のガイドは作成済み
チーム
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G5
3 メンバー
6のガイドは作成済み
コメント 1 件
where can i get the Loud speaker
Shamar Houston - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 272
