この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your phone does not vibrate, you should replace the vibrator. You will need to follow multiple prerequisite guides in order to complete this repair.
必要な工具と部品
Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
Remove the 4.0mm screw with a Phillips #000 screwdriver.
Using the blue plastic opening tool, remove the exterior cover.
もう少しです!
終わりに
