Remove SIM card tray with paperclip or SIM card tray removal tool.
Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
There is a patch of adhesive underneath the battery, which can make it difficult to remove.
Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
Remove the 4.0mm screw with a Phillips #000 screwdriver.
Using the blue plastic opening tool, remove the exterior cover.
Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
Use the plastic opening tool to remove the speaker.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
