この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your phone is not making any noise or the sounds are distorted while on speaker phone or playing videos, the speaker may need to be replaced. You will need to follow the battery replacement guide before you can start this repair guide.
必要な工具と部品
Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
Remove the 4.0mm screw with a Phillips #000 screwdriver.
Using the blue plastic opening tool, remove the exterior cover.
ある他の人がこのガイドを完成しました。
