はじめに
This guide will show you several blade removing techniques for when the blades are stuck somewhere on the motor of your Ninja Master Prep QB900B.
Be sure to have a tough cloth or a cut resistant glove on hand for the repair. In addition, make sure to turn off the device and unplug from the power outlet before beginning this repair.
必要な工具と部品
To remove the blades from each other, twist both blades in opposite directions and pull.
もう少しです!
ゴール
