メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Blackberry Z20 Leap LCD/Digitizer Replacement Replacement
必要な工具と部品
  1. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, Blackberry Leap Screen Replacement: 手順 1、 2の画像 1 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, Blackberry Leap Screen Replacement: 手順 1、 2の画像 2
    • Blackberry Z20 Leap (STR200-2) with a bad LCD. The first question is...Where are the screws?
    FixBotに聞いてみる
    コメントを追加
  2. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, remove screws: 手順 2、 2の画像 1 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, remove screws: 手順 2、 2の画像 2
    • The screws are behind the sticker beside the camera. Heat the sticker and use a knife to pry under the sticker to remove it. There are 2 screws which you need a T6 torx screwdriver to remove.
    FixBotに聞いてみる
    コメントを追加
  3. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: 手順 3、 3の画像 1 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: 手順 3、 3の画像 2 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: 手順 3、 3の画像 3
    • Push up on screen with thumbs once the screws have been removed. The screen assembly will now come away from the chassis. Be careful there is still some ribbon cables connected to the screen assembly.
    FixBotに聞いてみる
    コメントを追加
  4. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: 手順 4、 3の画像 1 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: 手順 4、 3の画像 2 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: 手順 4、 3の画像 3
    この手順で使用する道具:
    • In the top there is a connector where you have to lift the black part of the connector to remove the ribbon. I used tweezers to lift the connector and to remove the ribbon cable
    • Once the top ribbon is removed there is another cable connected in the middle. The phone will open up more to give you access. You will need to lift the black part of the connector to remove the ribbon. Again, I used tweezers. The screen assembly should now come away from the chassis
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Amanda Baxter
メンバー登録日: 02/08/16
217 ポイント
1ガイドが承認済み
8件のガイドコメント
Excellent Guide Amanda! thanks for the great work!
Xpider - 返信 共有
How to remove lcd from the frame (bezel)
Sani Shik - 返信 共有
Can you advise how this is done please...removing the lcd from the frame
zoe smith - 返信 共有
I bought a T6 torx screwdriver but it is too big for my Leap (STR200-1). Any idea what size torx I need? I'm guessing T5 but...
Dave - 返信 共有
Yep bought a T5 torx screwdriver and that did it
Dave - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 30
今までの合計 5,906
