メインコンテンツにスキップ
Blackberry Torch 9810 Motherboard Replacement
必要な工具と部品
  1. Blackberry Torch 9810 Motherboard Replacement, Phone cover: 手順 1、 2の画像 1 Blackberry Torch 9810 Motherboard Replacement, Phone cover: 手順 1、 2の画像 2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Motherboard Replacement, Battery Removal: 手順 2、 1の画像 1
    • Remove the battery
  3. Blackberry Torch 9810 Motherboard Replacement, Remove Screws: 手順 3、 1の画像 1
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Motherboard Replacement, Wiggle Wiggle: 手順 4、 2の画像 1 Blackberry Torch 9810 Motherboard Replacement, Wiggle Wiggle: 手順 4、 2の画像 2
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Motherboard Replacement, More Screws: 手順 5、 1の画像 1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
  6. Blackberry Torch 9810 Motherboard Replacement, Remove the Back: 手順 6、 3の画像 1 Blackberry Torch 9810 Motherboard Replacement, Remove the Back: 手順 6、 3の画像 2 Blackberry Torch 9810 Motherboard Replacement, Remove the Back: 手順 6、 3の画像 3
    • Use the plastic removal tool to remove the entire back cover.
  7. Blackberry Torch 9810 Motherboard Replacement, Small Antenna Wire: 手順 7、 1の画像 1
    • Unplug the black antenna wire from the logic board.
  8. Blackberry Torch 9810 Motherboard Replacement, Remove Ribbon Cables: 手順 8、 2の画像 1 Blackberry Torch 9810 Motherboard Replacement, Remove Ribbon Cables: 手順 8、 2の画像 2
    • Peel off the three ribbon cables
    • They are orange and located on each side as well as on the top of the logic board
    • The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
  9. Blackberry Torch 9810 Motherboard Replacement, Logic Board: 手順 9、 1の画像 1
    • Take out your logic board
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jocelyn Adorno
メンバー登録日: 10/16/14
296 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G6
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 3,392
