メインコンテンツにスキップ
  1. Remove the back cover of the phone Remove the back cover of the phone
    • Remove the back cover of the phone
  2. Remove the battery
    • Remove the battery
  3. Unscrew the four screws using the T6 screw driver.
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
  4. Slide the screen up. Remove front silver trim by using a plastic opening tools and wiggle it off.
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
  6. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  7. Use the plastic opening tools to remove the entire back off the phone. Use the plastic opening tools to remove the entire back off the phone. Use the plastic opening tools to remove the entire back off the phone.
    • Use the plastic opening tools to remove the entire back off the phone.
  8. Remove the three ribbon cables and the antenna wire by hand.
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
  9. The logic board will easily pull straight out.
    • The logic board will easily pull straight out.
  10. Remove the black sticker located above the logic board that contains the phone's serial number
    • Remove the black sticker located above the logic board that contains the phone's serial number
  11. Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
  12. Carefully separate the screen from the body.
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
  13. Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
  14. There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
  15. Push the cursor upwards and out of the socket. Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
まとめ
ある他の人がこのガイドを完成しました。
Jocelyn Adorno
メンバー登録日: 2014年10月16日
296 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G6
3 メンバー
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,173
