メインコンテンツにスキップ
Blackberry Torch 9800 Logic Board Replacement
必要な工具と部品
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: 手順 1、 2の画像 1 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: 手順 1、 2の画像 2
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: 手順 2、 2の画像 1 Blackberry Torch 9800 Logic Board Replacement: 手順 2、 2の画像 2
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: 手順 3、 3の画像 1 Blackberry Torch 9800 Logic Board Replacement: 手順 3、 3の画像 2 Blackberry Torch 9800 Logic Board Replacement: 手順 3、 3の画像 3
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: 手順 4、 2の画像 1 Blackberry Torch 9800 Logic Board Replacement: 手順 4、 2の画像 2
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: 手順 5、 2の画像 1 Blackberry Torch 9800 Logic Board Replacement: 手順 5、 2の画像 2
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Keegan Williams
メンバー登録日: 02/19/16
216 ポイント
2のガイドは作成済み
チーム
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016人のメンバー
OSU-GARVIN-S16S1G5
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 863
