メインコンテンツにスキップ
はじめに
This guide will be useful in replacing the back housing for the Blackberry RIM 7250. For this guide, you will need a plastic opening tool and a Torx #6 screwdriver head.
パーツ
パーツは指定されていません。
  1. Push the release button down and away from the device. Slide the cover off toward the bottom of the device, revealing the battery compartment. Slide the cover off toward the bottom of the device, revealing the battery compartment.
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Place your finger in the groove next to the battery. Lift your finger up to eject the battery from the battery compartment. Lift your finger up to eject the battery from the battery compartment.
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Remove the battery from the compartment. Remove the battery from the compartment. Remove the battery from the compartment.
    • Remove the battery from the compartment.
  4. iPhone X用修理キット
    Warranty up? No worries, we’ve got the fix.
    ショップを見る
    iPhone X用修理キット
    ショップを見る
  5. Remove  the four 10.7 mm Torx T6 screws. Remove  the four 10.7 mm Torx T6 screws.
    • Remove the four 10.7 mm Torx T6 screws.
  6. Remove the two 5 mm Torx T6 screws. Remove the two 5 mm Torx T6 screws.
    • Remove the two 5 mm Torx T6 screws.
  7. Hold the phone with one hand, with the bottom facing toward you.
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  8. Grab the back housing from the bottom and lift the housing away from you. Grab the back housing from the bottom and lift the housing away from you. Grab the back housing from the bottom and lift the housing away from you.
    • Grab the back housing from the bottom and lift the housing away from you.
まとめ
Noah Eckert
メンバー登録日: 2018年11月05日
519 ポイント
5のガイドは作成済み
チーム
IUPUI, Team S2-G4, Baechle Fall 2018 IUPUI, Team S2-G4, Baechle Fall 2018人のメンバー
IUPUI-BAECHLE-F18S2G4
3 メンバー
5のガイドは作成済み
コメント1件
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
