必要な工具と部品
Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
2 の人々がこのガイドを完成させました。
2 件のコメント
Trickiest part was removing the top piece. I used a razor blade to lift the edge, then a guitar pick to finish pulling it up. Thanks for the instructions.
Be careful with the razor blade or it will slice the top of the flex which you can see folded over the top of the frame. This is not what you will really want to do as you will now be replacing the flex too.
