メインコンテンツにスキップ
Blackberry DTek 60 Battery Replacement
必要な工具と部品
  1. Blackberry DTek 60 Battery Replacement, Detatch The Back Glass: 手順 1、 3の画像 1 Blackberry DTek 60 Battery Replacement, Detatch The Back Glass: 手順 1、 3の画像 2 Blackberry DTek 60 Battery Replacement, Detatch The Back Glass: 手順 1、 3の画像 3
    • Apply heat to the back glass around the edges. you can do this by one of three ways. 1) the iOpener Tool, 2) the hot air gun, and 3) the mobile dryer.
    • Lift the corner as much as possible. Should there be any excessive resistance, be sure to apply more heat.
    • begin working your way through the panel seam. should you encounter and snags, be sure ti dab a minimal amount of alcohal onto your pick, and that will help eat away at the adhesive
  2. Blackberry DTek 60 Battery Replacement, Remove the Back Panel: 手順 2、 1の画像 1
    • when there is enough glass Separating, begin to lift it slowly. There is a cable connecting your finger print sensor to the board. BE SURE NOT TO TEAR THIS
    • Lift from the left side to prevent damage to the sensor, and disconnect the connector from the board.
  3. Blackberry DTek 60 Battery Replacement, Lift The Battery: 手順 3、 1の画像 1
    • Disconnect the battery from the board, and Reheat the location to losen adhesive.
    • Try not to directly heat the battery. if you heat a bad battery, the Lithium may expand and cause damage to the board or self.
    • Gently lift the battery from the housing. The adhesive is tough, and may require some force. dont puncture the battery while doing this.
    • Follow the steps in reverse to reassemble the device.
    • Congratulations on your new battery
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Scott
メンバー登録日: 10/09/13
10,006 ポイント
4のガイドは作成済み
2 件のコメント
Thank you but I am not up to doing the work myself so I need a pro. I don’t trust myself.
kenval - 返信
DID IT … but need some clear instructions on where to insert device to help lift back cover. There is a small black lip running along the back panel.
Robert - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 6,256
