メインコンテンツにスキップ
Blackberry Curve 8320 Speaker Replacement
必要な工具と部品
  1. Blackberry Curve 8320 Speaker Replacement, Battery: 手順 1、 2の画像 1 Blackberry Curve 8320 Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Speaker Replacement: 手順 2、 1の画像 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Speaker Replacement, Front Panel: 手順 3、 3の画像 1 Blackberry Curve 8320 Speaker Replacement, Front Panel: 手順 3、 3の画像 2 Blackberry Curve 8320 Speaker Replacement, Front Panel: 手順 3、 3の画像 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Speaker Replacement: 手順 4、 2の画像 1 Blackberry Curve 8320 Speaker Replacement: 手順 4、 2の画像 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Speaker Replacement: 手順 5、 2の画像 1 Blackberry Curve 8320 Speaker Replacement: 手順 5、 2の画像 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Speaker Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Speaker Replacement: 手順 7、 1の画像 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 Speaker Replacement, Speaker: 手順 8、 3の画像 1 Blackberry Curve 8320 Speaker Replacement, Speaker: 手順 8、 3の画像 2 Blackberry Curve 8320 Speaker Replacement, Speaker: 手順 8、 3の画像 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 Speaker Replacement: 手順 9、 2の画像 1 Blackberry Curve 8320 Speaker Replacement: 手順 9、 2の画像 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 Speaker Replacement: 手順 10、 3の画像 1 Blackberry Curve 8320 Speaker Replacement: 手順 10、 3の画像 2 Blackberry Curve 8320 Speaker Replacement: 手順 10、 3の画像 3
    • Remove the back case.
    • The speaker is located on the back case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Christopher Aiello
メンバー登録日: 10/12/11
89 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S3G6
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,989
