メインコンテンツにスキップ
Blackberry Curve 8320 LCD Screen Replacement
必要な工具と部品
  1. Blackberry Curve 8320 LCD Screen Replacement, Battery: 手順 1、 2の画像 1 Blackberry Curve 8320 LCD Screen Replacement, Battery: 手順 1、 2の画像 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 LCD Screen Replacement: 手順 2、 1の画像 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 LCD Screen Replacement, Front Panel: 手順 3、 3の画像 1 Blackberry Curve 8320 LCD Screen Replacement, Front Panel: 手順 3、 3の画像 2 Blackberry Curve 8320 LCD Screen Replacement, Front Panel: 手順 3、 3の画像 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 LCD Screen Replacement: 手順 4、 2の画像 1 Blackberry Curve 8320 LCD Screen Replacement: 手順 4、 2の画像 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 LCD Screen Replacement: 手順 5、 2の画像 1 Blackberry Curve 8320 LCD Screen Replacement: 手順 5、 2の画像 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 LCD Screen Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 LCD Screen Replacement: 手順 7、 1の画像 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 LCD Screen Replacement, LCD Screen: 手順 8、 3の画像 1 Blackberry Curve 8320 LCD Screen Replacement, LCD Screen: 手順 8、 3の画像 2 Blackberry Curve 8320 LCD Screen Replacement, LCD Screen: 手順 8、 3の画像 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 LCD Screen Replacement: 手順 9、 2の画像 1 Blackberry Curve 8320 LCD Screen Replacement: 手順 9、 2の画像 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 LCD Screen Replacement: 手順 10、 3の画像 1 Blackberry Curve 8320 LCD Screen Replacement: 手順 10、 3の画像 2 Blackberry Curve 8320 LCD Screen Replacement: 手順 10、 3の画像 3
    • When all four screws are removed, the keyboard frame, screen housing, screen, and back casing can be separated.
    • The screen frame hooks on to the top of the motherboard with a small tab on the motherboard.
  11. Blackberry Curve 8320 LCD Screen Replacement: 手順 11、 1の画像 1
    • Place the motherboard on a flat surface with the LCD screen face up.
  12. Blackberry Curve 8320 LCD Screen Replacement: 手順 12、 3の画像 1 Blackberry Curve 8320 LCD Screen Replacement: 手順 12、 3の画像 2 Blackberry Curve 8320 LCD Screen Replacement: 手順 12、 3の画像 3
    • Using a plastic opening tool, gently pull the connector directly up from the motherboard.
    • Remove the LCD screen from the motherboard.
    • The screen is attached to the motherboard with adhesive.
終わりに
作成者
6人の作成者と共同で作成されました。
Christopher Aiello
メンバー登録日: 10/12/11
89 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S3G6
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,391
