はじめに
The purpose of this guide is to provide instructions for the Blackberry Curve 8320 front panel replacement.
Specifically, this guide will show you how to:
- Remove the battery
- Remove the front cover
- Replace the front panel
To repair this device there are no specific skills required however, when removing parts and reassembling the device it is important to handle the device with care. This device is an older model phone and therefore it is essential to follow the instructions carefully in order to ensure the longevity of the device.
必要な工具と部品
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
ある他の人がこのガイドを完成しました。
