メインコンテンツにスキップ
Blackberry Curve 8310 Motherboard Replacement
必要な工具と部品
  1. Blackberry Curve 8310 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Blackberry Curve 8310 Motherboard Replacement: 手順 2、 1の画像 1
    • Pry from the top of the battery to pull it out.
  3. Blackberry Curve 8310 Motherboard Replacement, Lens: 手順 3、 1の画像 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Blackberry Curve 8310 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Blackberry Curve 8310 Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Blackberry Curve 8310 Motherboard Replacement: 手順 6、 3の画像 1 Blackberry Curve 8310 Motherboard Replacement: 手順 6、 3の画像 2 Blackberry Curve 8310 Motherboard Replacement: 手順 6、 3の画像 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Blackberry Curve 8310 Motherboard Replacement, Keyboard: 手順 7、 1の画像 1
    • Remove the keyboard.
  8. Blackberry Curve 8310 Motherboard Replacement, Screen Housing: 手順 8、 1の画像 1
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. Blackberry Curve 8310 Motherboard Replacement: 手順 9、 2の画像 1 Blackberry Curve 8310 Motherboard Replacement: 手順 9、 2の画像 2
    • Now remove the left and right side panels.
  10. Blackberry Curve 8310 Motherboard Replacement: 手順 10、 3の画像 1 Blackberry Curve 8310 Motherboard Replacement: 手順 10、 3の画像 2 Blackberry Curve 8310 Motherboard Replacement: 手順 10、 3の画像 3
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. Blackberry Curve 8310 Motherboard Replacement, LCD Screen: 手順 11、 1の画像 1
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. Blackberry Curve 8310 Motherboard Replacement: 手順 12、 1の画像 1
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
  13. Blackberry Curve 8310 Motherboard Replacement, Motherboard: 手順 13、 1の画像 1
    • Separate the motherboard from the back case.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sean Willis
メンバー登録日: 01/26/12
229 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G32
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 15
今までの合計 2,366
