メインコンテンツにスキップ
Blackberry Bold 9900 Back Case Replacement
必要な工具と部品
  1. Blackberry Bold 9900 Back Case Replacement, Battery: 手順 1、 1の画像 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Back Case Replacement: 手順 2、 1の画像 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: 手順 3、 1の画像 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Back Case Replacement, MicroSD card: 手順 4、 2の画像 1 Blackberry Bold 9900 Back Case Replacement, MicroSD card: 手順 4、 2の画像 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Back Case Replacement, Keyboard: 手順 5、 2の画像 1 Blackberry Bold 9900 Back Case Replacement, Keyboard: 手順 5、 2の画像 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Back Case Replacement: 手順 6、 2の画像 1 Blackberry Bold 9900 Back Case Replacement: 手順 6、 2の画像 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Back Case Replacement: 手順 7、 1の画像 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Back Case Replacement: 手順 8、 2の画像 1 Blackberry Bold 9900 Back Case Replacement: 手順 8、 2の画像 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Back Case Replacement, Back Case: 手順 9、 1の画像 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Back Case Replacement: 手順 10、 1の画像 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Sowmika
メンバー登録日: 01/30/18
253 ポイント
2のガイドは作成済み
チーム
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 1,420
