はじめに
Replacing the back case of the BlackBerry Bold 9900 is a tedious task, but it will allow you to become more familiar with your device, increase the lifespan of the device, and reduce e-waste.
必要な工具と部品
Place phone screen down.
Use your finger to life upward on the battery case.
Pull the cover away from the battery.
The Mini-SIM card is located inside the red rectangle.
To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
The MicroSD card is located where the red rectangle is shown.
To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
3 の人々がこのガイドを完成させました。
