メインコンテンツにスキップ
Blackberry Bold 9650 LCD Screen Replacement
必要な工具と部品
  1. Blackberry Bold 9650 LCD Screen Replacement, Battery: 手順 1、 2の画像 1 Blackberry Bold 9650 LCD Screen Replacement, Battery: 手順 1、 2の画像 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 LCD Screen Replacement: 手順 2、 1の画像 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 LCD Screen Replacement, SIM Card: 手順 3、 1の画像 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 LCD Screen Replacement: 手順 4、 1の画像 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 LCD Screen Replacement, Back Chassis: 手順 5、 1の画像 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 LCD Screen Replacement: 手順 6、 1の画像 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 LCD Screen Replacement: 手順 7、 1の画像 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 LCD Screen Replacement: 手順 8、 1の画像 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 LCD Screen Replacement, Mother Board: 手順 9、 1の画像 1
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 LCD Screen Replacement: 手順 10、 1の画像 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 LCD Screen Replacement: 手順 11、 1の画像 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 LCD Screen Replacement: 手順 12、 1の画像 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 LCD Screen Replacement, Faceplate: 手順 13、 2の画像 1 Blackberry Bold 9650 LCD Screen Replacement, Faceplate: 手順 13、 2の画像 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  14. Blackberry Bold 9650 LCD Screen Replacement, LCD Screen: 手順 14、 1の画像 1
    • Turn the phone so it is facing up.
    • Use the plastic pry tool to gently pry out the screen.
    • The screen is glued to the phone so it may require some force to remove so use extra caution to prevent the screen from breaking.
  15. Blackberry Bold 9650 LCD Screen Replacement: 手順 15、 1の画像 1
    • Lift the screen away from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ryan
メンバー登録日: 03/12/12
696 ポイント
11のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G5
2 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 9
今までの合計 8,511
