メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Blackberry Bold 9650 Faceplate Replacement
必要な工具と部品
  1. Blackberry Bold 9650 Faceplate Replacement, Battery: 手順 1、 2の画像 1 Blackberry Bold 9650 Faceplate Replacement, Battery: 手順 1、 2の画像 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Faceplate Replacement: 手順 2、 1の画像 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Faceplate Replacement, SIM Card: 手順 3、 1の画像 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Faceplate Replacement: 手順 4、 1の画像 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Faceplate Replacement, Back Chassis: 手順 5、 1の画像 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Faceplate Replacement: 手順 6、 1の画像 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Faceplate Replacement: 手順 7、 1の画像 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Faceplate Replacement: 手順 8、 1の画像 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Faceplate Replacement, Mother Board: 手順 9、 1の画像 1
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Faceplate Replacement: 手順 10、 1の画像 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Faceplate Replacement: 手順 11、 1の画像 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Faceplate Replacement: 手順 12、 1の画像 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Faceplate Replacement, Faceplate: 手順 13、 2の画像 1 Blackberry Bold 9650 Faceplate Replacement, Faceplate: 手順 13、 2の画像 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Ryan
メンバー登録日: 03/12/12
696 ポイント
11のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G5
2 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,383
