メインコンテンツにスキップ
Blackberry Bold 9650 Buzzer-Loundspeaker Replacement
必要な工具と部品
  1. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Battery: 手順 1、 2の画像 1 Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Battery: 手順 1、 2の画像 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: 手順 2、 1の画像 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, SIM Card: 手順 3、 1の画像 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: 手順 4、 1の画像 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Back Chassis: 手順 5、 1の画像 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: 手順 6、 1の画像 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: 手順 7、 1の画像 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: 手順 8、 1の画像 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Buzzer-Loundspeaker: 手順 9、 1の画像 1
    • Use a plastic pry tool to remove the speaker.
    • Be careful removing removing the speaker as the plastic frame around the speaker is fragile.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Ryan
メンバー登録日: 03/12/12
696 ポイント
11のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G5
2 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 3,962
