メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
  1. Turn the device upside down. Using your finger, slide the silver cover release button towards the top of the device.
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Using your fingernails, lift the sides of the battery.
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Orient the device so the screen is facing the ground.
    • Orient the device so the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Gently pull out the SIM card.
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  6. Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
    • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  7. Orient the device so that the screen is facing you.
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  8. Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
    • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  9. Remove the back chassis by gently pulling the chassis back and forth.
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
終わりに
4 の人々がこのガイドを完成させました。
Ryan
メンバー登録日: 2012年03月12日
642 ポイント
11のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G5
2 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,986
