メインコンテンツにスキップ
Blackberry Bold 9000 LCD Screen Replacement
必要な工具と部品
  1. Blackberry Bold 9000 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 LCD Screen Replacement: 手順 2、 1の画像 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 LCD Screen Replacement: 手順 3、 1の画像 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 LCD Screen Replacement, Rear Case: 手順 4、 1の画像 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 LCD Screen Replacement: 手順 5、 1の画像 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 LCD Screen Replacement: 手順 6、 1の画像 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 LCD Screen Replacement, LCD Screen: 手順 7、 1の画像 1
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 LCD Screen Replacement: 手順 8、 1の画像 1
    • Using a spudger, lift the ribbon band in the upper right-hand corner up and away from the motherboard assembly until it disconnects.
  9. Blackberry Bold 9000 LCD Screen Replacement: 手順 9、 1の画像 1
    • Turn the motherboard assembly over.
    • Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
    • Do this step very slowly to avoid breaking the screen or the motherboard. The backing will eventually separate.
    • Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
    • With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Kelly
メンバー登録日: 01/18/12
566 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S8G17
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 7,538
