必要な工具と部品
With the same plastic opening tool, lift the motherboard up and out.
Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
Turn the motherboard assembly over.
Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
8 の人々がこのガイドを完成させました。
