メインコンテンツにスキップ
Blackberry 8700c Display Screen Replacement
必要な工具と部品
  1. Blackberry 8700c Display Screen Replacement, Display Screen: 手順 1、 3の画像 1 Blackberry 8700c Display Screen Replacement, Display Screen: 手順 1、 3の画像 2 Blackberry 8700c Display Screen Replacement, Display Screen: 手順 1、 3の画像 3
    • The required tools are pictured on the left (Picture 1). The tools are, left to right, spudger, T6 screwdriver, plastic opening tool.
    • Remove the back cover by pushing the button near the bottom of the phone (Picture 2) and sliding the cover off (Picture 3).
  2. Blackberry 8700c Display Screen Replacement: 手順 2、 2の画像 1 Blackberry 8700c Display Screen Replacement: 手順 2、 2の画像 2
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
  3. Blackberry 8700c Display Screen Replacement: 手順 3、 3の画像 1 Blackberry 8700c Display Screen Replacement: 手順 3、 3の画像 2 Blackberry 8700c Display Screen Replacement: 手順 3、 3の画像 3
    • Remove the inner back cover by unscrewing all three T6 screws (circled in Picture 1) with a T6 Torx screwdriver.
    • The inner back cover, removed in the next bullet, can be difficult to remove. You may need to use a plastic opening tool. Insert the plastic tool near the top of the phone between the cover and the phone. Gently pry the cover off.
    • Pull the inner back cover from the bottom towards you and up (Picture 2).
  4. Blackberry 8700c Display Screen Replacement: 手順 4、 3の画像 1 Blackberry 8700c Display Screen Replacement: 手順 4、 3の画像 2 Blackberry 8700c Display Screen Replacement: 手順 4、 3の画像 3
    • Remove the inner cover by unscrewing all four T6 screws with a T6 Torx screwdriver (circled in Picture 1).
    • A small black piece (circled in Picture 2 and displayed in Picture 3) will fall out when you remove the cover in the next bullet.
    • Lift the inner cover off the phone.
  5. Blackberry 8700c Display Screen Replacement: 手順 5、 2の画像 1 Blackberry 8700c Display Screen Replacement: 手順 5、 2の画像 2
    • The logic board removed in the next bullet is the entire circuit board circled in Picture 2.
    • Remove the logic board by lifting it away the front cover.
  6. Blackberry 8700c Display Screen Replacement: 手順 6、 3の画像 1 Blackberry 8700c Display Screen Replacement: 手順 6、 3の画像 2 Blackberry 8700c Display Screen Replacement: 手順 6、 3の画像 3
    • The clips disengaged in the next bullet may weaken and break after unclipping them.
    • Detach the display screen from the logic board by using a spudger to unclip the four clips holding the display screen (circled in Picture 1). Gently pull the display screen away from the logic board so that none of the clips are engaged.
    • The display screen is attached to the logic board by a metal ribbon. Remove the display screen by disengaging the ribbon lock. Use a spudger to push the thin black bar down (circled in Picture 2). Gently pull the display screen and ribbon out of the logic board.
  7. Blackberry 8700c Display Screen Replacement: 手順 7、 3の画像 1 Blackberry 8700c Display Screen Replacement: 手順 7、 3の画像 2 Blackberry 8700c Display Screen Replacement: 手順 7、 3の画像 3
    • Install the new display screen by reattaching it to the logic board. Reinsert the ribbon into the cable lock. Use the spudger to push the thin black bar up (circled in Picture 1).
    • Gently place the display screen against the logic board so that it is aligned with the clips. Use a spudger to engage all four clips (circled in Picture 3).
  8. Blackberry 8700c Display Screen Replacement: 手順 8、 1の画像 1
    • Replace the logic board by sliding it into the front cover.
  9. Blackberry 8700c Display Screen Replacement: 手順 9、 3の画像 1 Blackberry 8700c Display Screen Replacement: 手順 9、 3の画像 2 Blackberry 8700c Display Screen Replacement: 手順 9、 3の画像 3
    • The small black piece that is reattached in the next bullet will not snap into place until the inner cover is reattached. You will need to hold it in place until then.
    • Position the small black piece that fell out in Step 2 against the headphone jack on the side of the phone (circled in Picture 2).
    • Replace the inner cover on the phone by screwing in all four T6 screws (circled in Picture 3) with a T6 Torx screwdriver.
  10. Blackberry 8700c Display Screen Replacement: 手順 10、 3の画像 1 Blackberry 8700c Display Screen Replacement: 手順 10、 3の画像 2 Blackberry 8700c Display Screen Replacement: 手順 10、 3の画像 3
    • Replace the inner back cover by snapping the top of the cover against the phone. Push down on the bottom of the inner back cover to snap the entire cover into place.
    • Screw in all four T6 screws (circled in Picture 3) with a T6 Torx screwdriver.
  11. Blackberry 8700c Display Screen Replacement: 手順 11、 2の画像 1 Blackberry 8700c Display Screen Replacement: 手順 11、 2の画像 2
    • Replace the battery by positioning the top of the battery in the phone and snapping in the bottom.
  12. Blackberry 8700c Display Screen Replacement: 手順 12、 2の画像 1 Blackberry 8700c Display Screen Replacement: 手順 12、 2の画像 2
    • Replace the battery cover by sliding it against the device and snapping it into place.
ゴール
作成者
11人の作成者と共同で作成されました。
k3nt
メンバー登録日: 10/28/09
42 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S18G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 3,674
