メインコンテンツにスキップ
Blackberry 7520 Speaker Replacement
必要な工具と部品
  1. Blackberry 7520 Speaker Replacement, Battery: 手順 1、 2の画像 1 Blackberry 7520 Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Speaker Replacement: 手順 2、 3の画像 1 Blackberry 7520 Speaker Replacement: 手順 2、 3の画像 2 Blackberry 7520 Speaker Replacement: 手順 2、 3の画像 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Speaker Replacement, Speaker: 手順 3、 2の画像 1 Blackberry 7520 Speaker Replacement, Speaker: 手順 3、 2の画像 2
    • Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
  4. Blackberry 7520 Speaker Replacement: 手順 4、 2の画像 1 Blackberry 7520 Speaker Replacement: 手順 4、 2の画像 2
    • Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips.
    • Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
  5. Blackberry 7520 Speaker Replacement: 手順 5、 1の画像 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Speaker Replacement: 手順 6、 1の画像 1
    • Do not try to pull the two pieces apart. You may tear the antenna cable. Instead, fold the two pieces open to avoid stress on the cable.
  7. Blackberry 7520 Speaker Replacement: 手順 7、 1の画像 1
    • Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
  8. Blackberry 7520 Speaker Replacement: 手順 8、 3の画像 1 Blackberry 7520 Speaker Replacement: 手順 8、 3の画像 2 Blackberry 7520 Speaker Replacement: 手順 8、 3の画像 3
    • Insert a plastic opening tool between the speaker and the case. Then pry the speaker out.
    • To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
終わりに
作成者
8人の作成者と共同で作成されました。
Nathan
メンバー登録日: 01/18/10
31 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S5G7
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,480
