はじめに
For removing and replacing the Blackberry 7520 battery, follow this guide.
ツール
工具は必要ありません。
パーツ
パーツは必要ありません。
Turn the phone upside down.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
コメントを追加する
Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
コメントを追加する
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
コメントを追加する
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
コメントを追加する
ゴール
Nathan
メンバー登録日: 2010年01月18日
31 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S5G7
5 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,429
