メインコンテンツにスキップ
Blackberry 7105t Speaker Replacement
必要な工具と部品
  1. Blackberry 7105t Speaker Replacement, Blackberry 7105t Disassembly: 手順 1、 1の画像 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Speaker Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Speaker Replacement: 手順 3、 1の画像 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Speaker Replacement: 手順 4、 1の画像 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Speaker Replacement: 手順 5、 3の画像 1 Blackberry 7105t Speaker Replacement: 手順 5、 3の画像 2 Blackberry 7105t Speaker Replacement: 手順 5、 3の画像 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Speaker Replacement: 手順 6、 1の画像 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Speaker Replacement: 手順 7、 1の画像 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Speaker Replacement, Speaker: 手順 8、 2の画像 1 Blackberry 7105t Speaker Replacement, Speaker: 手順 8、 2の画像 2
    • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
    • Place the three clips in plastic bag and set aside.
    • Once clips are removed, you will have full access to remove the speaker.
終わりに
作成者
9人の作成者と共同で作成されました。
CeeJay
メンバー登録日: 10/28/09
19 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S9G17
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,177
