メインコンテンツにスキップ
Blackberry 7105t Keyboard Replacement
必要な工具と部品
  1. Blackberry 7105t Keyboard Replacement, Blackberry 7105t Disassembly: 手順 1、 1の画像 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Keyboard Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Keyboard Replacement: 手順 3、 1の画像 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Keyboard Replacement: 手順 4、 1の画像 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Keyboard Replacement: 手順 5、 3の画像 1 Blackberry 7105t Keyboard Replacement: 手順 5、 3の画像 2 Blackberry 7105t Keyboard Replacement: 手順 5、 3の画像 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Keyboard Replacement: 手順 6、 1の画像 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Keyboard Replacement: 手順 7、 1の画像 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Keyboard Replacement, Second Disassembly: 手順 8、 1の画像 1
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
  9. Blackberry 7105t Keyboard Replacement, Keyboard: 手順 9、 2の画像 1 Blackberry 7105t Keyboard Replacement, Keyboard: 手順 9、 2の画像 2
    • Use a plastic opening tool to lift up the two black clips indicated in the picture.
    • Hold on to the keyboard while unfastening the clips.
    • The keyboard will detach once the clips are unfastened.
終わりに
作成者
10人の作成者と共同で作成されました。
CeeJay
メンバー登録日: 10/28/09
19 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S9G17
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 2,820
