メインコンテンツにスキップ
BlackBerry Z30 Battery Replacement
必要な工具と部品
  1. BlackBerry Z30 Battery Replacement, Battery cover: 手順 1、 1の画像 1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Battery Replacement, Remove SIM and Media Card: 手順 2、 1の画像 1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Battery Replacement, Unscrewing the LCD panel: 手順 3、 3の画像 1 BlackBerry Z30 Battery Replacement, Unscrewing the LCD panel: 手順 3、 3の画像 2 BlackBerry Z30 Battery Replacement, Unscrewing the LCD panel: 手順 3、 3の画像 3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Battery Replacement, Separate the LCD from the Frame: 手順 4、 2の画像 1 BlackBerry Z30 Battery Replacement, Separate the LCD from the Frame: 手順 4、 2の画像 2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Battery Replacement, Remove the LCD: 手順 5、 2の画像 1 BlackBerry Z30 Battery Replacement, Remove the LCD: 手順 5、 2の画像 2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Battery Replacement, LCD Panel removal: 手順 6、 1の画像 1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Battery Replacement, Untie the System board: 手順 7、 1の画像 1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Battery Replacement, Untie the System board Part 2: 手順 8、 1の画像 1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Battery Replacement, Untie the system board Part 3: 手順 9、 1の画像 1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Battery Replacement, System board removal: 手順 10、 1の画像 1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
  11. BlackBerry Z30 Battery Replacement, Remove the Rear Camera: 手順 11、 2の画像 1 BlackBerry Z30 Battery Replacement, Remove the Rear Camera: 手順 11、 2の画像 2
    • Use a pair of pliers to remove the rear facing camera
  12. BlackBerry Z30 Battery Replacement, Remove the Battery: 手順 12、 3の画像 1 BlackBerry Z30 Battery Replacement, Remove the Battery: 手順 12、 3の画像 2 BlackBerry Z30 Battery Replacement, Remove the Battery: 手順 12、 3の画像 3
    • If this is the original battery, it might be hold down by VERY strong adhesive on the top, middle and bottom part. Be careful not to damage the battery
    • As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue.
終わりに
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Hans
メンバー登録日: 10/20/14
1,920 ポイント
6のガイドは作成済み
チーム
Mero IT Services Mero IT Services人のメンバー
Business
1 メンバー
6のガイドは作成済み
10 件のコメント
Good guide, but one caveat - when removing the battery, the adhesive is pretty much directly attached to the NFC "plate" (a flexible square membrane with a pair of contacts on the bottom left side of the battery). If you try to extract the battery, you will have difficulty not destroying this membrane. Do not use a wedge - you must slowly remove the battery, preferably using a heat gun to loosen the glue.
Or get a battery already glued into a back plate.
wfines - 返信
Thank you for the detail. I will add a notice about that on the last step.
Hans -
How to change the USB port
Yass Tra - 返信
Thank you !!!
Yass Tra - 返信
OMG! The procedure looks horrible !!
mwlacey - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 23,415
