はじめに
Use this guide to replace the motherboard on your BlackBerry Z10.
  1. This is the easiest repair I've completed yet. This is the easiest repair I've completed yet.
    • This is the easiest repair I've completed yet.
  2. The rear panel pops off easily. Grab the opening at the bottom and work your way around. The rear panel pops off easily. Grab the opening at the bottom and work your way around. The rear panel pops off easily. Grab the opening at the bottom and work your way around.
    • The rear panel pops off easily. Grab the opening at the bottom and work your way around.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. There is NO adhesive on this device. NO ADHESIVE!! There is NO adhesive on this device. NO ADHESIVE!!
    • There is NO adhesive on this device. NO ADHESIVE!!
  5. There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw. There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw. There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw.
    • There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw.
  6. Disconnect the logic board connector near the top and left side. Underneath the connector on the left side, there's two other connectors. Disconnect those. Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
    • Disconnect the logic board connector near the top and left side.
    • Underneath the connector on the left side, there's two other connectors. Disconnect those.
    • Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
まとめ
20 の人々がこのガイドを完成させました。
Daniel Edwards
メンバー登録日: 2010年09月21日
694 ポイント
1ガイドが承認済み
For what is the second Screwdriver and what size is the right on?
Stefan Schenk - 返信
Will changing the motherboard assembly change my imei. I am wondering if I need to check the imei of the new motherboard to make sure it isn’t from a flag phone before install it.
phnark - 返信
統計データを表示:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 45
今までの合計 16,015
