必要な工具と部品
Turn phone over to the backside.
Press down on the lower portion of the back cover.
Slide the lower portion down to remove the cover and reveal the battery.
Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
Disconnect the tab attached to the interior casing from the LCD Screen by gently pulling the tab up and away from the phone.
Use the Plastic Opening Tool to pry the LCD Screen out.
Grab and remove the middle bar located on the bottom of the phone.
Once the bar is removed, a small wire will be revealed. Remove the wire using your tweezers.
There are two places that wire is clipped in. To disconnect the wire, gently pull up on the wire until it pops off of the connector.
3 の人々がこのガイドを完成させました。
