メインコンテンツにスキップ
BlackBerry World Edition 8830 Front and Back Casing Replacement
必要な工具と部品
  1. BlackBerry World Edition 8830 Front and Back Casing Replacement, Battery: 手順 1、 3の画像 1 BlackBerry World Edition 8830 Front and Back Casing Replacement, Battery: 手順 1、 3の画像 2 BlackBerry World Edition 8830 Front and Back Casing Replacement, Battery: 手順 1、 3の画像 3
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 2、 1の画像 1
    • Remove the battery from the phone.
  3. BlackBerry World Edition 8830 Front and Back Casing Replacement, Front and Back Casing: 手順 3、 2の画像 1 BlackBerry World Edition 8830 Front and Back Casing Replacement, Front and Back Casing: 手順 3、 2の画像 2
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  4. BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 4、 3の画像 1 BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 4、 3の画像 2 BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 4、 3の画像 3
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  5. BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 5、 2の画像 1 BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 5、 2の画像 2
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
  6. BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 6、 3の画像 1 BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 6、 3の画像 2 BlackBerry World Edition 8830 Front and Back Casing Replacement: 手順 6、 3の画像 3
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Martha de Maria y Campos
メンバー登録日: 04/12/12
121 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-27, Amido Spring 2012 Cal Poly, Team 17-27, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G27
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 699
