メインコンテンツにスキップ
BlackBerry Tour 9630 Trackball Replacement
必要な工具と部品
  1. BlackBerry Tour 9630 Trackball Replacement, Battery: 手順 1、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement, Battery: 手順 1、 2の画像 2
    • Position the phone so that the keyboard is facing down and the back is facing up.
  2. BlackBerry Tour 9630 Trackball Replacement: 手順 2、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement: 手順 2、 2の画像 2
    • Push the center silver button upwards to release the back cover.
    • Take the back cover off and set it to the side.
  3. BlackBerry Tour 9630 Trackball Replacement: 手順 3、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement: 手順 3、 2の画像 2
    • Grip the battery where the light grey half circles are located and pull up.
    • Set the removed battery to the side with the back cover.
  4. BlackBerry Tour 9630 Trackball Replacement, Keypad: 手順 4、 1の画像 1
    • If there is an SD card, press gently on the card and slide up to remove.
    • If there is a SIM card, press gently on the card and slide left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
  5. BlackBerry Tour 9630 Trackball Replacement: 手順 5、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement: 手順 5、 2の画像 2
    • Using an opening tool, pry the top plastic covering off. As shown in the second picture.
    • There is glue holding the top plastic covering. Additional pressure may be needed.
  6. BlackBerry Tour 9630 Trackball Replacement: 手順 6、 1の画像 1
    • Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
  7. BlackBerry Tour 9630 Trackball Replacement: 手順 7、 1の画像 1
    • Remove the back casing.
    • This may take some wiggling to fully remove the part.
  8. BlackBerry Tour 9630 Trackball Replacement: 手順 8、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement: 手順 8、 2の画像 2
    • Using a small opening tool, pry up the pop ribbon cable from the motherboard.
  9. BlackBerry Tour 9630 Trackball Replacement: 手順 9、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement: 手順 9、 2の画像 2
    • Using a small opening tool, remove the side antenna cable.
  10. BlackBerry Tour 9630 Trackball Replacement: 手順 10、 1の画像 1
    • Gently push up on the keyboard from below to snap the front cover off.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 Trackball Replacement: 手順 11、 1の画像 1
    • Remove the keypad.
  12. BlackBerry Tour 9630 Trackball Replacement, Trackball: 手順 12、 2の画像 1 BlackBerry Tour 9630 Trackball Replacement, Trackball: 手順 12、 2の画像 2
    • Remove the trackball.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mia
メンバー登録日: 01/13/15
524 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 768
