メインコンテンツにスキップ
BlackBerry Torch 9860 Handset Disassembly
必要な工具と部品
  1. BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: 手順 1、 2の画像 1 BlackBerry Torch 9860 Handset Disassembly, BlackBerry Torch 9860: 手順 1、 2の画像 2
    • Depress the battery cover release button and remove the battery cover
    • Remove the battery from the phone before continuing.
    • Slide the yellow button toward the battery to eject the SIM card
    • Remove the MicroSD card from the SD slot (if present)
  2. BlackBerry Torch 9860 Handset Disassembly: 手順 2、 2の画像 1 BlackBerry Torch 9860 Handset Disassembly: 手順 2、 2の画像 2
    • There will be a silver bezel around the edge (the dog ate mine!)
    • Insert pry tool near the padlock icon and gently work your way around the bezel to pry it off and reveal the screws.
  3. BlackBerry Torch 9860 Handset Disassembly: 手順 3、 2の画像 1 BlackBerry Torch 9860 Handset Disassembly: 手順 3、 2の画像 2
    • Grab your T5 Torx screwdriver, and remove all 8 screws
    • Be careful when taking out screws. The silver ones go in the corners, black ones in the middle
  4. BlackBerry Torch 9860 Handset Disassembly: 手順 4、 2の画像 1 BlackBerry Torch 9860 Handset Disassembly: 手順 4、 2の画像 2
    • With the 8 screws removed, you can gently pry the back cover off. Be gentle, as it is still connected by a ribbon cable
    • Gently pry ribbon cable off, and then you will have the back cover fully removed
  5. BlackBerry Torch 9860 Handset Disassembly: 手順 5、 3の画像 1 BlackBerry Torch 9860 Handset Disassembly: 手順 5、 3の画像 2 BlackBerry Torch 9860 Handset Disassembly: 手順 5、 3の画像 3
    • The next step is to remove the board.
    • There are 3 ribbon cables connected to it
    • Disconnect the first ribbon cable
    • When you remove the second ribbon cable it will reveal the third ribbon cable
  6. BlackBerry Torch 9860 Handset Disassembly: 手順 6、 3の画像 1 BlackBerry Torch 9860 Handset Disassembly: 手順 6、 3の画像 2 BlackBerry Torch 9860 Handset Disassembly: 手順 6、 3の画像 3
    • With the 3 ribbon cables disconnected you can gently pry the board up and away from phone
    • With the board removed, you can then simply lift out the LCD display
  7. BlackBerry Torch 9860 Handset Disassembly: 手順 7、 1の画像 1
    • Once the LCD is removed, the handset disassembled.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
daniel
メンバー登録日: 12/22/11
380 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 7,109
