メインコンテンツにスキップ
BlackBerry R900M Scroll Wheel Replacement
必要な工具と部品
  1. BlackBerry R900M Scroll Wheel Replacement, Case Disassembly: 手順 1、 1の画像 1
    • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
  2. BlackBerry R900M Scroll Wheel Replacement: 手順 2、 1の画像 1
    • Remove the backside of the device and set aside for later use.
  3. BlackBerry R900M Scroll Wheel Replacement: 手順 3、 2の画像 1 BlackBerry R900M Scroll Wheel Replacement: 手順 3、 2の画像 2
    • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
  4. BlackBerry R900M Scroll Wheel Replacement: 手順 4、 1の画像 1
    • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
  5. BlackBerry R900M Scroll Wheel Replacement: 手順 5、 2の画像 1 BlackBerry R900M Scroll Wheel Replacement: 手順 5、 2の画像 2
    • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
    • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • One is located below the scrollwheel.
    • Another is located behind the screen.
  6. BlackBerry R900M Scroll Wheel Replacement, Scroll Wheel: 手順 6、 2の画像 1 BlackBerry R900M Scroll Wheel Replacement, Scroll Wheel: 手順 6、 2の画像 2
    • Pinch the white plastic clip that connects the ribbon of the scroll wheel to the logic board.
    • Gently wiggle and pull upwards to remove the scroll wheel.
終わりに
作成者
3人の作成者と共同で作成されました。
Steven Jackowski
メンバー登録日: 04/18/10
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 33-83, Johann Spring 2010 Cal Poly, Team 33-83, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G83
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 2,018
