メインコンテンツにスキップ
BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball
必要な工具と部品
  1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: 手順 1、 3の画像 1 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: 手順 1、 3の画像 2 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: 手順 1、 3の画像 3
    • Remove four screws total on the back of the phone casing near edge of battery area.
    • Two screws that are closer to the top of the phone are protected by plastic stoppers. Remove them then remove the screws.
    • There are two more screws on either side of where the battery was located. remove them as well.
  2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 2、 3の画像 1 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 2、 3の画像 2 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 2、 3の画像 3
    • Remove the bottom plastic piece.
    • This may require prying from a few different directions. The plastic blue prying tool featured here may be required.
  3. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 3、 3の画像 1 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 3、 3の画像 2 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 3、 3の画像 3
    • Once the keypad is removed, the buttons on the sides of the phone will fall out.
    • You will need to loosen the board from the right side opposite the charging ports.
    • Pull gently towards the right side so the ports clear the plastic casing.
    • Gently flip the board over to the left.
  4. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 4、 3の画像 1 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 4、 3の画像 2 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 4、 3の画像 3
    • On the back of the circuit board you will find a small rectangular blue piece with a black 'L' shape in the middle.
    • Gently detach this from the back of the main board.
    • Now you may fully remove the main board.
  5. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 5、 3の画像 1 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 5、 3の画像 2 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: 手順 5、 3の画像 3
    • What is left inside the phone is the roller ball.
    • Gently use the plastic blue tool to detach it from the frame.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Ashley
メンバー登録日: 04/15/13
318 ポイント
3のガイドは作成済み
チーム
SUNY Cortland, Team 1-5, Getto Spring 2013 SUNY Cortland, Team 1-5, Getto Spring 2013人のメンバー
SUNYCORT-GETTO-S13S1G5
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 829
