はじめに
This guide details the removal of the rear, bottom and side covers; the frame, motherboard and front cover; and the keypad and trackball of the Blackberry Pearl 8100.
ツール
パーツ
パーツは指定されていません。
Push the button indicated by the yellow marker to remove the rear cover.
Remove the battery (not pictured).
Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
Use the T6 Torx screwdriver to remove the screws.
Separate the keypad (first picture) and trackball (second picture) from the front cover.
Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
ある他の人がこのガイドを完成しました。
