メインコンテンツにスキップ
BlackBerry Pearl 8100 Disassembly
必要な工具と部品
  1. BlackBerry Pearl 8100 Disassembly, Rear Cover: 手順 1、 1の画像 1
    • Push the button indicated by the yellow marker to remove the rear cover.
    • Remove the battery (not pictured).
  2. BlackBerry Pearl 8100 Disassembly, Screws underneath the rear cover: 手順 2、 1の画像 1
    • Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
  3. BlackBerry Pearl 8100 Disassembly, Bottom Cover: 手順 3、 2の画像 1 BlackBerry Pearl 8100 Disassembly, Bottom Cover: 手順 3、 2の画像 2
    • Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
  4. BlackBerry Pearl 8100 Disassembly, Side Cover: 手順 4、 2の画像 1 BlackBerry Pearl 8100 Disassembly, Side Cover: 手順 4、 2の画像 2
    • Use the plastic opening tool to remove the side covers.
    • The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
  5. BlackBerry Pearl 8100 Disassembly, More screws: 手順 5、 1の画像 1
    • With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
    • Use the T6 Torx screwdriver to remove the screws.
  6. BlackBerry Pearl 8100 Disassembly, Frame: 手順 6、 2の画像 1 BlackBerry Pearl 8100 Disassembly, Frame: 手順 6、 2の画像 2
    • With the screws removed, the frame can be detached.
  7. BlackBerry Pearl 8100 Disassembly, Logic Board: 手順 7、 2の画像 1 BlackBerry Pearl 8100 Disassembly, Logic Board: 手順 7、 2の画像 2
    • Use the plastic opening tool to separate the motherboard from the front cover.
    • While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
  8. BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: 手順 8、 2の画像 1 BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: 手順 8、 2の画像 2
    • Separate the keypad (first picture) and trackball (second picture) from the front cover.
    • Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
    • Keep the trackball intact. The trackball has extremely small magnetic bolts underneath that are difficult to reassemble.
  9. BlackBerry Pearl 8100 Disassembly, Complete: 手順 9、 1の画像 1
    • These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Justin
メンバー登録日: 10/06/14
150 ポイント
2のガイドは作成済み
チーム
Aristotle Aristotle人のメンバー
Community
5 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 22
今までの合計 668
