メインコンテンツにスキップ
BlackBerry Curve 8900 Motherboard Replacement
必要な工具と部品
  1. BlackBerry Curve 8900 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Motherboard Replacement: 手順 2、 2の画像 1 BlackBerry Curve 8900 Motherboard Replacement: 手順 2、 2の画像 2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Motherboard Replacement, Motherboard: 手順 3、 1の画像 1
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Motherboard Replacement: 手順 5、 1の画像 1
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Motherboard Replacement: 手順 6、 2の画像 1 BlackBerry Curve 8900 Motherboard Replacement: 手順 6、 2の画像 2
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Motherboard Replacement: 手順 7、 2の画像 1 BlackBerry Curve 8900 Motherboard Replacement: 手順 7、 2の画像 2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Motherboard Replacement: 手順 8、 1の画像 1
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Motherboard Replacement: 手順 9、 2の画像 1 BlackBerry Curve 8900 Motherboard Replacement: 手順 9、 2の画像 2
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Motherboard Replacement: 手順 10、 2の画像 1 BlackBerry Curve 8900 Motherboard Replacement: 手順 10、 2の画像 2
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
終わりに
3 の人々がこのガイドを完成させました。
作成者
16人の作成者と共同で作成されました。
Johnny Tran
メンバー登録日: 09/10/11
473 ポイント
4のガイドは作成済み
チーム
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011人のメンバー
CUESTA-ZIPPERIAN-F11S1G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 4,080
