メインコンテンツにスキップ
BlackBerry Curve 8530 Trackpad Replacement
必要な工具と部品
  1. BlackBerry Curve 8530 Trackpad Replacement, Battery: 手順 1、 2の画像 1 BlackBerry Curve 8530 Trackpad Replacement, Battery: 手順 1、 2の画像 2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Trackpad Replacement: 手順 2、 1の画像 1
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Trackpad Replacement, Keypad: 手順 3、 2の画像 1 BlackBerry Curve 8530 Trackpad Replacement, Keypad: 手順 3、 2の画像 2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Trackpad Replacement: 手順 4、 2の画像 1 BlackBerry Curve 8530 Trackpad Replacement: 手順 4、 2の画像 2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Trackpad Replacement: 手順 5、 3の画像 1 BlackBerry Curve 8530 Trackpad Replacement: 手順 5、 3の画像 2 BlackBerry Curve 8530 Trackpad Replacement: 手順 5、 3の画像 3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Trackpad Replacement: 手順 6、 2の画像 1 BlackBerry Curve 8530 Trackpad Replacement: 手順 6、 2の画像 2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
  7. BlackBerry Curve 8530 Trackpad Replacement, Screen: 手順 7、 3の画像 1 BlackBerry Curve 8530 Trackpad Replacement, Screen: 手順 7、 3の画像 2 BlackBerry Curve 8530 Trackpad Replacement, Screen: 手順 7、 3の画像 3
    • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
    • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
    • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
  8. BlackBerry Curve 8530 Trackpad Replacement: 手順 8、 3の画像 1 BlackBerry Curve 8530 Trackpad Replacement: 手順 8、 3の画像 2 BlackBerry Curve 8530 Trackpad Replacement: 手順 8、 3の画像 3
    • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
    • Use pressure to unlatch the screen from the clips.
    • Now that these clips have been undone, the screen should lift up easily.
  9. BlackBerry Curve 8530 Trackpad Replacement, Motherboard: 手順 9、 2の画像 1 BlackBerry Curve 8530 Trackpad Replacement, Motherboard: 手順 9、 2の画像 2
    • Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
  10. BlackBerry Curve 8530 Trackpad Replacement: 手順 10、 3の画像 1 BlackBerry Curve 8530 Trackpad Replacement: 手順 10、 3の画像 2 BlackBerry Curve 8530 Trackpad Replacement: 手順 10、 3の画像 3
    • Now the motherboard will lift up out of the plastic backing of the phone.
  11. BlackBerry Curve 8530 Trackpad Replacement, Trackpad: 手順 11、 3の画像 1 BlackBerry Curve 8530 Trackpad Replacement, Trackpad: 手順 11、 3の画像 2 BlackBerry Curve 8530 Trackpad Replacement, Trackpad: 手順 11、 3の画像 3
    • Flip over the motherboard.
    • There is another torx screw near the middle of the motherboard on the left side.
    • Using the T5 Torx Screwdriver, remove the screw and the metal casing.
    • Note: Distinguish this screw from the others for reassembly purposes.
    • Detach the clip holding the track pad in.
  12. BlackBerry Curve 8530 Trackpad Replacement: 手順 12、 1の画像 1
    • Remove the trackpad from the motherboard.
    • Now you are ready to reassemble the phone
ゴール
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Chris
メンバー登録日: 04/20/11
227 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G13
3 メンバー
5のガイドは作成済み
コメント 1 件
No need to full disassemble the phone. Just remove the back and the battery and unscrew the T5 screw, presto 20 minutes saved.
willdickerson - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 15,473
