メインコンテンツにスキップ
BlackBerry Curve 8530 Keypad Replacement
必要な工具と部品
  1. BlackBerry Curve 8530 Keypad Replacement, Battery: 手順 1、 2の画像 1 BlackBerry Curve 8530 Keypad Replacement, Battery: 手順 1、 2の画像 2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Keypad Replacement: 手順 2、 1の画像 1
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Keypad Replacement, Keypad: 手順 3、 2の画像 1 BlackBerry Curve 8530 Keypad Replacement, Keypad: 手順 3、 2の画像 2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Keypad Replacement: 手順 4、 2の画像 1 BlackBerry Curve 8530 Keypad Replacement: 手順 4、 2の画像 2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Keypad Replacement: 手順 5、 3の画像 1 BlackBerry Curve 8530 Keypad Replacement: 手順 5、 3の画像 2 BlackBerry Curve 8530 Keypad Replacement: 手順 5、 3の画像 3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Keypad Replacement: 手順 6、 2の画像 1 BlackBerry Curve 8530 Keypad Replacement: 手順 6、 2の画像 2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
終わりに
To reassemble the device, follow the instructions in reverse order.
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Cory Davis
メンバー登録日: 04/19/11
503 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G13
3 メンバー
5のガイドは作成済み
コメント 1 件
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 6,397
