メインコンテンツにスキップ
BlackBerry Curve 8520 Motherboard Replacement
必要な工具と部品
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: 手順 1、 2の画像 1 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: 手順 1、 2の画像 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: 手順 2、 2の画像 1 BlackBerry Curve 8520 Motherboard Replacement, Battery: 手順 2、 2の画像 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: 手順 3、 2の画像 1 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: 手順 3、 2の画像 2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: 手順 4、 2の画像 1 BlackBerry Curve 8520 Motherboard Replacement: 手順 4、 2の画像 2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: 手順 5、 3の画像 1 BlackBerry Curve 8520 Motherboard Replacement: 手順 5、 3の画像 2 BlackBerry Curve 8520 Motherboard Replacement: 手順 5、 3の画像 3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: 手順 6、 3の画像 1 BlackBerry Curve 8520 Motherboard Replacement: 手順 6、 3の画像 2 BlackBerry Curve 8520 Motherboard Replacement: 手順 6、 3の画像 3
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
    bb is nt a freely phone is a phone bcz of ringing some how it is nt
    tankiso - 返信
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: 手順 8、 2の画像 1 BlackBerry Curve 8520 Motherboard Replacement: 手順 8、 2の画像 2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
終わりに
32 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Matt
メンバー登録日: 04/07/11
1,722 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-62, Walters Spring 2011 Cal Poly, Team 9-62, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S9G62
5 メンバー
5のガイドは作成済み
コメント 1 件
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 36,780
