はじめに
The process of replacing the trackpad of your BlackBerry Bold 9700 will allow you to become familiar with your device and restore full functionality.
必要な工具と部品
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Flip the board over so that the LCD display is against the the surface of your work space.
Use a plastic opening tool to gently remove the ribbon connector located on the right-hand side of the board.
3 の人々がこのガイドを完成させました。
