はじめに
If you do not see any broken or missing keys on your BlackBerry Bold but when you press a button there is no response, the keyboard membrane may need replacing. Replacing this membrane on any device can be difficult, but by following the steps in this guide you will have a new keyboard membrane installed in no time.
必要な工具と部品
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Use a conventional hair dryer to heat up the keyboard membrane.
On medium or low heat evenly heat up the membrane in the range of 5 to 10 minutes
ある他の人がこのガイドを完成しました。
